Latest activity
  • Unknown member reacted to re_solidworks's post in the thread extraction designers with Like Like.
    I didn't get this impression. I collaborated and collaborated with mechanical engineers and did not match any difference. idem with the...
  • rpor66 replied to the thread create a customizable block library with a lisp.
    in the zip file you find the pdf with explanations on installation and use.
    Give me a few days and publish the files in this discussion
  • Davimont replied to the thread solid edge was dealer (variable control panel).
    At the moment I wouldn't be useful but it's always a good job!
  • Unknown member reacted to Be_on_edge's post in the thread solid edge was dealer (variable control panel) with Like Like.
    I forgot to announce the 0.5 step directly to 0.6fixed a bug in handling the units during variable limits settings2d\3d tracker...
  • Fabietto replied to the thread shape nozzles warm room.
    there are nozzles of many diameters, with standard size you can find ø16 external nozzles, ø4 the internal channel, and arrives to...
    I'm sorry, but I don't understand anything or anything. I'm going intuition. . if you remove plastic -> add steel -> you should have no...
    hi, unclear question, and therefore I cannot answer. . is the mold existing or are you planning it? 4 nozzles inject on the same piece...
  • jenuary replied to the thread problem print view trimmed.
    You did well to report. well the fact that you found a loophole. Thank you for sharing
  • jenuary replied to the thread solidworks24 properties from files.
    try repairing the installation or reinstalling the 2024. also feel the assistance before you go on vacation
    hi, I imported the step and from me it is fine, I realized that the problem lies in the system options --> matter. I think you've...
  • insert a note with syntax &pro_mp_mass and this will be interpreted with the value of weight.
    the assistance he says, have you tried to hear it?
    try to attach one of those files, so I try to test
  • GP. replied to the thread how to avoid scientific notation.
    in autolisp:"....the real numbers are stored in double-precision mobile comma format, providing at least 14 significant precision...
