Latest activity
  • it works on all lwpoly, although, as already mentioned by confutatis in post #20, it would be perhaps more logical to reason on the...
  • czar replied to the thread welding indication on thin sheet.
    so much to speak: the company has instructed a second company to our unknowing, this received the drawings with the logo deleted so that...
  • for such actions it is better to use fdu then bring you behind a lot of information (features, relationships, param, qote, ...)
  • Unknown member reacted to nicksoft's post in the thread substitution parameter in text sketch without re-entry (in sketch) with Like Like.
    Hi. if you created a sketch curve, select the text icon and you specified "use parameter", every time you change the value of the...
    yesterday they explained to me that the usual supplier charged another company, I have no idea whether to our unconscious or what. We're...
  • GP. replied to the thread scale elevation beads.
    hi, I would set "directly" the new elevation with setpropertyvalue:(defun c:elevscale () (princ "\nselect polylines:") (setq entities)...
  • Peppe replied to the thread evidence part in tree.
    even with inventor if you select a part is highlighted in the left tree, of course if that part is nested you have to open the various...
    Hello is the only way. What does not this command do for your habits?
  • czar replied to the thread development calandar tube.
    I understood whistles for whistles, I thought it was to make a tube of sheet metal, instead the tube is the artifact of departure and...
    create a sketch of an open circle at a point of a distance that can suit you according to the thickness, extrude sheet (you can define...
    thanks 1000 to all. to date we have never put indications according to norm, agreements have been made with the supplier where it is...
    Thanks massive. Am I wrong if I say it should not serve the indication of the thickness of welding?
  • hi, I'm doubtful about the type of indication to be placed (always if needed) on the junction of a thin sheet thickness (2mm), therefore...
  • Unknown member reacted to Mirco T.'s post in the thread table in autocad with Like Like.
    Thank you. @peppe You have a solution for everything! !
  • czar replied to the thread tool check vincoli.
    in general where I work problems always arise for the different philosophy/mentality of the various users who access the files together...
