x3di
hi to everyone, I wanted to know if someone uses the productstream to store files and can help me.
I found 2 problems
The first is that I'm missing the local area models:redface: Suddenly I go to open a new file and the models (set by the company) are no more
second, it is a question, possible problem: if you make a synchronization of the local area you can lose the files not archived? When you sync all files appear and you need to check out all those you don't want to sync. . But if you click "ok" for a "unroar error", what happens?
I found 2 problems
