autodesk productstream
  • Thread starter Thread starter x3di
x3di
hi to everyone, I wanted to know if someone uses the productstream to store files and can help me.
I found 2 problems
The first is that I'm missing the local area models:redface: Suddenly I go to open a new file and the models (set by the company) are no more:eek:
second, it is a question, possible problem: if you make a synchronization of the local area you can lose the files not archived? When you sync all files appear and you need to check out all those you don't want to sync. . But if you click "ok" for a "unroar error", what happens?
I found 2 problems
I hope that Chinese velsion is a schelzo, veil?
have you read the lethals to avoid them?
Bye.
I found 2 problems
Can I ask you how you are with productstream? I'm in the process of choice and if I could get some info, I'd be grateful.
I found 2 problems
I do not have ps but only vault, if once you archive the files you disappear from the local area is because you have checked the item "close files and delete copies of work" (I recommend selecting it). As for synchronization I can't answer you, vault doesn't have it.
