cose scomode with swx
cacciatorino
I'm sorry, but I'm in the first place, and so I'm struggling to do some things that are ultra-rapid about me, and here's very long and tedious, so I wanted to ask regular users if there's a way to solve them.
1) the processing referred to in the post:http://www.cad3d.it/forum1/showthread.php?t=156632) environment together:
in solid edge I have a function that is called "memorize relationships", useful to save in the side file the bonds together so the next time I insert it I don't have to redefine them. in if I'm two clicks with the context menu, here' instead I found the "coupling rows" but I have to repeat all the surfaces to mate again, which actually the cad already knows being the piece placed.
3) environment together:
How do I access the anagraphies of the part or subaxieme? If I do it inside the axieme with the context menu, it seems to me that I have to open the single part in part environment, is there something faster?
4) environment together
the function "another selection" seems a bit slender, is it possible to filter only certain types of entities (for example, only parts, and not even geometric primitives)? Moreover with if when I stop with the mouse in the middle of various components, he automatically opens the function "another selection", without having to recall it with two clicks (one for the context menu and one for the function). Can you do it in swx?
5) environment part
when I change sketch, if you automatically put in orthogonal view on the sketch plane, and once finished it returns to the previous view (it's a set function, I can tell him not to do this).
Can you do it in swx? otherwise it becomes a little boring to direct the view every time.
6) multibody part environment (this if it does not exist)
It seems to me that it is not possible to assign the anagraphic propies to each solid, right? I wanted to use the function to make the carpentry welds but if I can't then get to the cutting distinction maybe it's better than using the traditional axieme.
7) environment part
change odds: if I want to change a quota I have to do it over double click, instead with if only one click and opens the casellin to change the value, can you also do it with swx?
8) environment part
Does the diameter share exist in the sketchy environment? I can't find it, but if I find it very useful when I need to model turning (see example attached)
9) environment swx explorer
with if I can for example change the name and folder of only some files of the axieme (for example, 30 on the 50 components that create the axieme), but doing it with a single operation. But here it seems to me that I work on the whole axieme or I have to work on a file at a time, did I get it wrong?
the next questions to the next deepening on swx.
5) environment part
7) environment part
8) environment part
1- see in the discussion, I managed to reach the problem.
2- I should do tests, use mating rules only for commercial elements.
3- If you configure tab builder is very simple and fast.
4-use little, have you tried to use filters while using other selection?
5- What happens to you now? do you behave in the same way both in creation and change? I have to check that there are options, you could set up if to place normal or not, but I don’t think you can then return to the previous orientation. look that if you get used to orienting “the swx” it becomes easy and fast. ctrl+n (where n from 1 to 6 = orthogonal views – 7 isometrics and 8 normal a) allows you to quickly orient yourself as a keyboard, touching an axis of the terna will guide you normal to the latter, pressing the bar exit the views and you can orient yourself touching one.
6- you do if you enable welded and fill in folders under “welding elements” at the top in the feature manager. use it because it is a power, in 2010 you can also manage the sheets with multibody and it is really powerful (and fast).
7- I would say that every cad has its operating mode. I don't think that's possible. try to act on the function of windows appropriate (but I don't know if it does mess). I still can’t get used to proes (which I’ve had for more than a year)... or you do one and use the other or with both of you never feel “at home”.
8- Of course, it is enough that there is a construction line as an axis and first from the third click of positioning the quota beyond the axis. i.e. click the element, click the axis, go beyond the axis and place the diametral quota.
9- I should do tests, use swx explorer in rare cases, I have pdm and normally do less.
It's okay here.
I can only capture the first couple. For example, in solid edge I can save in the file of the part of the screw the constraint for the sogttotesta and the concentricity bond for the stem. at that point when I translate the component into the axieme, just click the flange plane and the hole and the screw is positioned. But here I can only associate the first constraint, while the second one I have to insert it with the totally manual procedure.
Speaking of constraints, is there any way to "block" the concentric bond to rotation? in itself and this saves me a bond when I insert the above screw.
See, very nice!
continues to seem a bit slender, let's say that the context menu is not so much, there are too many functions of which some not very useful.. .
remains as it was, and if I put myself in an orthogonal view when I close the sketch, it stays like this.
These functions are actually interesting, although the "common view" function of if it seems more intuitive.
I'm trying to figure something out!
See, it works!
Here, unfortunately, things are a little gray on swx, it seems made for you to buy the pdm, only then I think it's a little hard to work when you're with the laptop and the pdm isn't there.
another interesting thing I found in swx:
in itself I have the "ownership management" function that opens me in a table all the anagraphic features of the files present in the axieme. from there I can easily change the propies, even with the copy-paste between one column and another. In swx I haven't found anything equivalent so far, but I've seen that I can insert a bom in the assembly and make changes from there. It's not up to the instrument of itself but better than nothing!
also you hunter in the world of sw?? :) How come this choice?? I have just entered it and unfortunately I can not help you but we have here the mythical king who will give us a hand. If it can comfort you also I have had difficulties of passage and unfortunately getting used to a cad different from the usual one is always a mess.
It's a client's request that you can't say no for which he's been working in 2d so far.
I would like to say that 'this money would save me very willingly, to devote them to more interesting uses' (type intercontinental air travel tickets....).
Fortunately, if and swx are not brothers but less cousins... .
ah ok!!!chapter what you mean...the same thing happened to me in the past.in good luck!
I don't know if you're in good hands. I have done some courses but I am above all a practical one. . .
It's okay here.
See, very nice!
See, it works!
2- for screws and bolts try to select only the circular edge both coincidental and concentric.
4- I think it's just a matter of habit. . You have to "pay" the pass.
5- I think it's just working, I still have to check. . .
6- perhaps we open a discussion in which we put together all the problems related to welded.
9- here I can help you little. from what I know you do to one by one.
in solidworks where is the continuous quotation (chain)?
very simple, there is not! or better there is only with the ordered quotas.
I do not know exactly how it means _braunfish_ but in drawing there is also the base line. is fast, position and maintains "interline", simple and useful for machine processing with a fixed start (a little like the order but with "traditional" layout/visualization).
rather sometimes I would be useful a call "coordinated", i.e. that you give me at one point simultaneously x and y only with a clik, without quota lines or extension, starting from a zero previously assigned.. (for the cn frestore that you write the program on board machine, without covering the views in the table of lines of extreme and crossed quota).
can you do _re_?
can you do _re_?
what I mean is the chain quotation (in autocad smooth there is from version 1). in practice it is like the ordered quotation but it marks the partial instead of the reference always from the zero point.
be careful that you risk falling in love with sw and abandon the old fuck if!! :wink:
The first approach is not very comforting, although at 90% it is a lack of desire to get used to a new software.
of things that really lack in swx I found a serious couple (propie management and revision managers) and some small ones (especially the quotation in the table environment is not comparable), instead I saw that swx does something in the environment part (the pattern of processing according to an arbitrary scheme) that instead if it does not.
Even the interface seems to me a lot more messed up, at least comparing it to the v20 because the new releases of if they are an incredible step back in this aspect, maybe even the swx were victim of imperious ribbonification or simply I still have to get used to it.
No, you can't.
and this I have inserted it as an improvement to insert through their immemore form, I ask every release, I release the ba** and the hotline... There's nothing to do. ! !
all the time it touches me to quote to order, disengage the chain, disalline and quote x e y. cheppa***!:eek:
Who knows, maybe in 2 they listen to us!!! :finger:
I quote for myself the draft quotation if it remains the best one compared to other cads I use
two more difficulties:
1) in solid edge I can see in 3d the quotas of a feature, including those of the sketch that generates it. The purpose is to change in one step both the sketch and the extrusion. Can you do it in swx? so far I have only managed to make sketch modification, get out of the sketch, regenerate (automatic), change feature, regenerate (automatic).
2) if I cut the edge to which are referred of the "basic line rates", then to hang them back to the new edge I have to pass all one by one? with if reattaching the first they also hang up all the others (of course, being referred to the same origin...).
if you double-click a feature face you will see the odds of both the sketch and the feature (extrusion depth, revolution angle, number of repetitions, repeat step etc.), the changes and then regenerate at once only
and for the odds, a virtual sharp is normally created automatically and the odds remain attached to this.
thanks, it works perfectly, although it would not be bad to see the piece change instantly after the change, without asking for regeneration.
