warburg
will be the hot, but I can no longer understand how to find the dwg file (called site plan.dwg) with which you can start the exercise with the 2010 version in Italian, described in the pdf file "architecturemttuta4ita" quoted in this post by giove1: http://www.cad3d.it/forum1/showthread.php?t=13995Basically, on page 50 of the pdf it is said that "in the new project dialog box, click the browse at the template file, then open training files\metric\templates\defaultmetric.rte." ok, after it is said: "1 in the Insert tab, import group, click import cad. 2 in the cad format dialog box:
■ in the left pane, click training files and select common\site plan.dwg."
but in the window on the left I do not have this folder, and even if I climb up in the hierarchy this file is not found.
If some pious soul gives me a suggestion, it's really hot...
C
C
