info for exercise
  • Thread starter Thread starter warburg
warburg
will be the hot, but I can no longer understand how to find the dwg file (called site plan.dwg) with which you can start the exercise with the 2010 version in Italian, described in the pdf file "architecturemttuta4ita" quoted in this post by giove1: http://www.cad3d.it/forum1/showthread.php?t=13995Basically, on page 50 of the pdf it is said that "in the new project dialog box, click the browse at the template file, then open training files\metric\templates\defaultmetric.rte." ok, after it is said: "1 in the Insert tab, import group, click import cad. 2 in the cad format dialog box:
■ in the left pane, click training files and select common\site plan.dwg."
but in the window on the left I do not have this folder, and even if I climb up in the hierarchy this file is not found.
If some pious soul gives me a suggestion, it's really hot... :-)
C
Hello everyone, I exhume this old post because I am also doing my first steps with revit and I have printed this exercise. the problem is that I also do not find this imaginative site plan.dwg.
I have searched wide and long but nothing:
Could some pious soul have it?
Early thanks!
the file path should be: training files\common\site plan.dwg :(
Thank you for the answer! I responded by email (with attachment) ;-)
thanks to good evening!
hi, to find all the files related to the exercises you must download from the autodesk site the various packages referred to the English version - metric (not imperial of course!) and extract them where the readme file says (the Italian one does not go, use that in English). to continue with the guide you need all the files (this is because each exercise is done using pre-built projects step by step, thus avoiding to take 'behind' errors )
http://usa.autodesk.com/adsk/servlet/item?siteid=123112&id=13080067&linkid=9243097
Yeah, well, guys, come on. It's a simple plan with some level curve... It's just who knows that...
who has been using autocad for a while, knows how to build level curves.. It doesn't take a degree in geology. .
Early thanks!
yes, sin that all the exercise is based on those files, not only dwg but the various families, the various passages (in which some elements are already inserted, I don't know where to find them). .
It is true that you could build a thing about the same as the commands are the same but if you have made a guide and basic models with some peculiarities to deal with almost all the problems to learn effectively in a short time better to use it no? so I have time to graduate in geology. .
