opua
Hello everyone, a simple probable question for many of you, with which command in caia v5 inserts the material to a part?
Thank you very much:1 to assign it
2 to display it as such
we waved
and then drag it on the part1 per assegnarlo
it is not possible because it is like in realityIf instead in one part I have two prisms, for example a parallelepiped on which I extrude a cylinder, can I attribute a material different to each of the elements or do I have to apply one only to the whole part?
If you model a hammer and the handle you want it wood... are two different catparts that then assemble in a catproduct
instead... with colors then diversify as you want in every body
? ? ?attention:
1. You need to drag him to the file name. practically you must ensure that the material has not been assigned to the main body but to the whole object.
only if you model a component that has two different materials then attribute to each body the exact material. for example injection parts (plastic + steel).
Right, thank you very muchit is not possible because it is like in reality
I do not agree with what you say for two reasons:what does falonef say?
But in my opinion it is not the exact procedure.
each catpart must be single
how do you then with the distinct base manage a catpart with different body with different materials?
curious.Right, thank you very much
Damn, you've moved me.I do not agree with what you say for two reasons:
1) write that one thing "... is not possible." is different from writing "...in my opinion, it is not the exact procedure...", at least if we are in the Italian language.
so increase the confusion of this thread, since falonef, correctly, says that you can do it.
and it's for me too.
there are many functions (e.g. using 3d elements projections in sketches such as references or using the edge fillet command in the surface module only to say 2 randomly) that in many situations are not recommended .
but this does not mean that "it is not possible" or that, more simply, in some limited cases it is not possible to use them.
Among other things, even in v6, they maintained this possibility to assign different materials to different body, a sign that, in some cases, it is useful to have this possibility.
2) "the procedure that goes well" depends on so many things. If, generally, I find myself with your indication of having a structure with a solid parametric and a material for each catpart, all grouped under product, which simplifies the management of bom, this does not exclude that there are other ways of working (which can be more 'marked for some realities') and that they provide, instead, a single capart
This avoids the risk of creating "loop" in the links, for example, because everything "the group of catpart files" points to a single reference, instead of having "ragnatele" of links, where a catpart is linked to another catpart which, in turn, is linked to the catpart that you are trying to change.
