Musical76
Hey, guys.
I'm a mechanical designer, working in a biomedical company.
I am new to the community and I hope I have identified the right forum to ask for advice about my problem.
I need to make a small dissipator on a driver of an electronic card.
I am looking for a supplier of a profiled or extruded aluminum that reminds a lot of that of a heat sink, in pennies those you often see on audio amplifiers.
some measures:
support base (one side corresponds to the profile extraction section)
17mmx17mm (drive or processor base)
h_max= 8/10 mm
made with an aluminum base to stick to the driver and many vertical fins.
do you know someone or work in some company that can provide these profiles? ?
I thank you from now on for the kind answers.
in which case this is the wrong forum, I would kindly ask you to indicate the correct one to ask these questions.
good work at all
Gab
some measures:
h_max= 8/10 mm
good work at all
Gab
