aluminium profiles
  • Thread starter Thread starter Musical76
Musical76
Hey, guys.
I'm a mechanical designer, working in a biomedical company.
I am new to the community and I hope I have identified the right forum to ask for advice about my problem.
I need to make a small dissipator on a driver of an electronic card.
I am looking for a supplier of a profiled or extruded aluminum that reminds a lot of that of a heat sink, in pennies those you often see on audio amplifiers.
some measures:
support base (one side corresponds to the profile extraction section)
17mmx17mm (drive or processor base)
h_max= 8/10 mm
made with an aluminum base to stick to the driver and many vertical fins.
do you know someone or work in some company that can provide these profiles? ?
I thank you from now on for the kind answers.
in which case this is the wrong forum, I would kindly ask you to indicate the correct one to ask these questions.
good work at all
Gab
Hey, guys.
some measures:
h_max= 8/10 mm
good work at all
Gab
Maybe if you get a sketch or a profile design you need
you can find what you need
Anyway
if you do not find the specific sez
the profile matrix make all manufacturers on your design
costs roughly around 1500-2000 €
in many cases if super supply exceeds 4-5 q.te give it
aluminum extruded costs roughly 2.38-2.50-3.0 € per kg then depends
From quantities
waiting for a match
Good job
Maybe if you take a look at sites like www.distrelect.it or http://it.rs-online.com/web/of dissipators of all species, shapes and sizes you find already beautiful that ready and tested for every specific use.
start with something commercial, therefore safe and above all easily available, and then according to the development of the product calculations if it is necessary to make them extrude on purpose.
that is, if a post-domain need to produce in quantity of the order of the thousands of pieces, then you would already know what kind and size to build, without risking to throw time and money for matrices, test productions, etc.
p.s. for my brother shiren: to have the matrix from extrusion in gift of quintals to produce it needs at least 15 or 20. and in some cases 50 are not enough.
Obviously staying at the prices you indicated. if instead one agrees to pay the profile a 2 or 3 euro per kg. more...
Hello big brother mecc
It's always a pleasure to read
I guarantee that right from your side last week I made a quote for a string
between 5-7 -10 q per month from March to September
they gave us the free string
and we were discussing having powder coating as well
Will it be the crisis???? ? ? ? ? ? ? ? ? ?
I wish you a great evening
Good morning.
I am in the debate because I would like to ask you an opinion.
I sized a cooling system with forced ventilation for a slightly bizarre application...cmq the shape of the heatsink is a classic compact heatsink but instead of being straight is about 3/4 ring with a bending radius of about 300mm. at this point (because I am mainly a calculist) I was doubtful: "I build it with an extruded or I rub the wings and then piego the wings and I fill them/brase/what is best?"
What do you think?
Good morning.
What do you think?
Hello zax....
a sketch as well manual would be more suitable
Thank you very much
Here is a similar fac of the model.
Hello zax
I see a square tubular with fins
for the "long" line
pulling an extruded round maybe some probes there is
you can only make an assembly of the particulates (I would say lathe)
if the dimensions allow it perhaps in fusion to gravity with shell soul
Hey, guys.
some measures:
h_max= 8/10 mm
good work at all
Gab
if you turn to a good supply warehouse for electrotechnical you find different types, already ready to cut to size.
Mar
Hey, guys.
some measures:
h_max= 8/10 mm
good work at all
Gab
hi I wanted to tell you that I work in a company that produces heat sinks.
with a little luck we could find the heat sink for you, this is the company site http://www.nuovati-zeta.com/
