m_arquati
I created a sheet, and assembled other sheets on this. Now to fix the other plates I have inserted threaded pins (which I modeled as parts) using the function-driven repetition and as a function I used those of the holes of the other plates.
all in one together. I have therefore the knuckle pins stick on the base sheet and are concentric with the holes of the others that are above it.
It's okay!
but when do I have to make the table of the only base sheet with the position of the pins and the development?
have you already found a solution?
Thank you so much!
It's okay!
Thank you so much!
