Exatem
As for the bandage, it starts from the thickness greater in correspondence of the keel, then as it rises, the thickness is reduced. you can start with 10, 12mm and get to 5. We'll see him later.What thicknesses and sizes are used?
for development which factor is used ?
With regard to the real structure, the size of the central paramezzale and the others is determined by formulas dictated for example by the rhine. In the case of military ships, it is not observed what the agency says as, the parameters adopted, are more restrictive.
Anyway here:
I started talking about it.in the attached pdf you will find the explanation of the minimum size of the central fender. I chose a certain material but nothing prohibits using others. in this case the necessary coefficients are in previous posts.
Let's go ahead and then I'll be more precise. Now I want to go see your file.
hasta the view!
