project ladice
  • Thread starter Thread starter Exatem
in fact we are no longer forced to power them on the net, but we can well use the electronics to control the speed and angular acceleration of the rotating field, from when the rotor is still until the desired speed. to do this you need a minimum of logic in the driver of the engine, in fact this to provide the current with the right phase must always know the position of the rotor and does it with a retroaction that can be based on encoder or on sensors with a lobby effect.
The brushless are also controlled like this. the drag field is generated by the feedback error. for my curiosity, how do drives work? pwm, four quadrants... ward leonard:biggrin:. . .
I'm pretty ignorant about it, but are you sure it's a synchronous engine? who brings it to synchronism speed? and the propellers must be necessarily variable step?
How do you mean propellers?
because in this case the answer is no.
Underwater propulsion propulsion propellers are fixed, with a generally higher standard number (standard 7) and with an optimized profile to delay cavitation.
It's a serious matter, we hope it's resolved!
:eek:
given the messages I had in private, I think I generated a wasp.. .
99% error was mine and not the system. I did "quota", then I copied it is pasted into the private message and I will continue to write on the wrong page.
Excuse me. . .
today they all work in pwm, from PC fans to naval ones, so much thinks mitsubishi electic (or even ir) to provide such powerful modules:
http://www.mitsubishichips.com/global/products/powermod/index.htmlthe pwm, that is the modulation by pulse amplitude allows to obtain from logic the sinusoidal signal of power that generates the rotary magnetic field, in other words you control position and speed of the rotor.
What do you think? and I wanted to ask dragon if I can reduce the angle of the axis line from 4 to 2.5 - 2.6 degrees. Is he having trouble?
I stayed at a helical diameter of 3600 mm with preliminary data,
I am waiting to know the finals (power, turns).
with such diameter keeping me on the side of the safe I need from center axis to the famine no less than 2200 mm.
you can decrease the inclination, then stretch the line and increase the losses and the risk of vibration.
We're going too hard, I give up.
it was in perspective to use an electric motor without reducer, then I thought to place it as much as possible, shortening of much the axis line. in the center/try then I put batteries and generators.
but I am also waiting for directions on the solution.
I'm out of the sown.
no, the purpose of this "project", besides boating to friend sampom for the next holidays, is clearly "didactic". so well explaining, deepening, of any kind and subject. What I wrote is because I read it on articles that treat the subject but from them to understand something... is that I am more of a "lamaire" than electrons, so if you go to the bottom of some arguments, I lose myself.
but there are others who read, who will certainly be interested in deepening the matter.
So continue, I read, but I will hardly understand anything.
boys are in big cases, I have to finish preparing the documentation for a tender (contractor's tender) and I think I will also work Saturday and Sunday ... I think the surfaces I'll make you at the beginning of next week, you don't want and have patience.
Have you not finished the hull and already think of the tender??? :biggrin::biggrin:
(the tender is also the boat of support for the boats for the Laodice we could think of a mangusta 80'? )
it betrays us and beyond all for competition of small cabotage...:cool:
That's the locomotive tender!
Max understood that we are making a pyrocorvetta!
:biggrin:
Well...the ship has been charled again!!!
I wanted to know your opinion about the part we like to take care of me and my "kompagna"...that is...the style (that big words!!!)! :biggrin:
because what we're doing is a "experimental" project. I thought I'd cut off the many stylistic elucubrations I'm doing!
so... once you define the functions of the various levels. ..I will (of course I do not take the exclusive...who has better ideas can quietly "put on") to define an acceptable stylistic line to be able to at least stand!
what do u think about,guys? :smile:
The ship didn't get angry... fortunately I have some things to do I struggle to find the time to finish.
Give me 5 or 6 days to crash it:-)
I am preparing the iron plan for the various bridges but wait max for the correct hull. I'm really messed up right now. I know I can't do anything this week.
idem.
I'm always on the move, and I don't have a moment of breath in my office.
..but we'll come back to strength!:finger:
Marco:smile:
Greetings to everyone.
After a quick round of consultations, the anomina yards trimarrano would have thought to continue in this area to post discussions, suggestions, ideas and, what else, while in the area "work in progress" you could open a parallel discussion in which to post exclusively the progress work. you have to study some details. For example, I almost finished the top of the irons with regard to the hold and cover (for the bottom irons and the neat appearance of the max surfaces).
in "work and progress" the 2 tables should be placed. but the determination of the irons that make them as we present it? I mentioned a post in which I gave indications on how to dimensional the paramezzals, longitudinal, etc. according to you how should you proceed? tables on one side and methods of calculation from another?
I hope I've been clear.
I look forward to your enlightening advice.
I got a gift from a friend. It is the 1965 reprint of a file dating back to 1911 (first edition, corrected in 1918), on the method of structural calculation of the ships. Almost...
