Er Presidente
It's a serious matter, we hope it's resolved!I wrote it like mp.
The brushless are also controlled like this. the drag field is generated by the feedback error. for my curiosity, how do drives work? pwm, four quadrants... ward leonard:biggrin:. . .in fact we are no longer forced to power them on the net, but we can well use the electronics to control the speed and angular acceleration of the rotating field, from when the rotor is still until the desired speed. to do this you need a minimum of logic in the driver of the engine, in fact this to provide the current with the right phase must always know the position of the rotor and does it with a retroaction that can be based on encoder or on sensors with a lobby effect.
How do you mean propellers?I'm pretty ignorant about it, but are you sure it's a synchronous engine? who brings it to synchronism speed? and the propellers must be necessarily variable step?
given the messages I had in private, I think I generated a wasp.. .It's a serious matter, we hope it's resolved!
ho trovato questo:http://www.diegm.uniud.it/petrella/...ry stuff chapter 5 (d) - azionamenti msmp.pdfI'm pretty ignorant about it, but are you sure it's a synchronous engine? who brings it to synchronism speed? and the propellers must be necessarily variable step?
today they all work in pwm, from PC fans to naval ones, so much thinks mitsubishi electic (or even ir) to provide such powerful modules:for my curiosity, how do drives work? pwm, four quadrants... ward leonard:biggrin:. . .
I stayed at a helical diameter of 3600 mm with preliminary data,What do you think? and I wanted to ask dragon if I can reduce the angle of the axis line from 4 to 2.5 - 2.6 degrees. Is he having trouble?
We're going too hard, I give up.today they all work in pwm, from PC fans to naval ones, so much thinks mitsubishi electic (or even ir) to provide such powerful modules:
http://www.mitsubishichips.com/global/products/powermod/index.htmlthe pwm, that is the modulation by pulse amplitude allows to obtain from logic the sinusoidal signal of power that generates the rotary magnetic field, in other words you control position and speed of the rotor.
it was in perspective to use an electric motor without reducer, then I thought to place it as much as possible, shortening of much the axis line. in the center/try then I put batteries and generators.I stayed at a helical diameter of 3600 mm with preliminary data,
I am waiting to know the finals (power, turns).
with such diameter keeping me on the side of the safe I need from center axis to the famine no less than 2200 mm.
you can decrease the inclination, then stretch the line and increase the losses and the risk of vibration.
I'm out of the sown.We're going too hard, I give up.
no, the purpose of this "project", besides boating to friend sampom for the next holidays, is clearly "didactic". so well explaining, deepening, of any kind and subject. What I wrote is because I read it on articles that treat the subject but from them to understand something... is that I am more of a "lamaire" than electrons, so if you go to the bottom of some arguments, I lose myself.I'm out of the sown.
Have you not finished the hull and already think of the tender??? :biggrin::biggrin:boys are in big cases, I have to finish preparing the documentation for a tender (contractor's tender) and I think I will also work Saturday and Sunday ... I think the surfaces I'll make you at the beginning of next week, you don't want and have patience.
it betrays us and beyond all for competition of small cabotage...Have you not finished the hull and already think of the tender??? :biggrin::biggrin:
(the tender is also the boat of support for the boats for the Laodice we could think of a mangusta 80'? )
You'd like...that we like to take care of me and my "kompagna". . . :
idem.I am preparing the iron plan for the various bridges but wait max for the correct hull. I'm really messed up right now. I know I can't do anything this week.
