ReFazzi
Good morning
I have a very serious problem for a couple of times:
in a completely bound assembly I made a change to a part by moving holes. the assembly did not update, in practice the part bound to the modified holes did not follow the shift.
constraints did not make mistakes. the version was inv 2010. not even the closing and reopening of inventor solved the problem.
there were no derived parts, mirrored, was not used adactivity.
my retailer analyzed the file solved me using "recreate everything" from "management" without knowing how to give me an explanation of what happened.
now I have been presented with the same problem with 2011. this is a very serious thing because working normally you can take references and do work based on components that are not in the right place.
someone noticed this problem, you know what it is generated and how it can be avoided?
for now we are forced to use the command recreates everything very often.
