ChIP_83
just start the application, after the initial splash screen (with a slightly slower loading than usual) gives me this error:
the file journal, or rather the files, since it creates one every start is this:
I also restored the system at a time when revit went (2 days ago) but nothing, does not want to know.
of course I also reinstalled the program, cleaning all registry keys and residual folders, and then reinstalling it.
I tried restoring from revit setup.
I also tried to install the update 1, nothing.
the version is 2011.
help
after which the program closes (or better not even starts).an irreversible error occurred. the application will be finished. all data have been saved recently, so you do not need to create recovery files.
I tried everything, I don't know what to do. .' 0:< thrashing monitor is off.
' 0:< initial vm: avail 1884 mb, used 45 mb, peak 45; ram: avail 2258 mb, used 56 mb, peak 45
'c 18-sep-2010 23:29:55.070; 0:< started recording journal file
' build: 20100326_1700
dim jrn
set jrn = crsjournalscript
' 0:< options::loadoptions: m_strdatalibrarylocations=metric library=c:\programdata\autodesk\rac 2011\metric library,metric detail library=c:\programdata\autodesk\rac 2011\metric library\componenti di dettaglio (defaultlib==\library)
' 0:< delta vm: avail -42 -> 1843 mb, used +15 -> 60 mb, peak +15 -> 60 mb; ram: avail -23 -> 2236 mb, used +21 -> 78 mb, peak +21 -> 78 mb
'c 18-sep-2010 23:29:56.255; 0:< ->initinstance
' 0:< delta vm: avail -190 -> 1653 mb, used +79 -> 140 mb, peak +80 -> 140 mb; ram: avail -105 -> 2131 mb, used +103 -> 182 mb, peak +103 -> 182 mb
' 0:< untimely construction of manager receiverrbssystemproperties
' 0:< delta vm: avail -119 -> 1535 mb, used +28 -> 169 mb, peak +31 -> 172 mb; ram: avail -43 -> 2089 mb, used +35 -> 218 mb, peak +38 -> 220 mb
' 0:< dbg_info: non-revit resource or bad type fragment: line 495 of .\resourceselector.cpp.
' 0:< delta vm: avail -35 -> 1500 mb, used +34 -> 204 mb, peak +69 -> 242 mb; ram: avail -30 -> 2060 mb, used +23 -> 242 mb, peak +31 -> 251 mb
' 0:< exception occurred
'c 18-sep-2010 23:30:06.197; 0:< exceptioncode=0xe0434f4d exceptionflags=0x00000001 exceptionaddress=753d9617
' 0:< system (mb) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< ram statistics: 2060 / 3327 242=inuse 251=peak
0:< vm statistics: 1500 / 2047 204 = 242=peak
' 0:< taskdialog "an irreversible error occurred. the application will be finished. all data have been saved recently, so you do not need to create recovery files. "
'commonbuttons': close
'defaultbutton: close
0:< delta vm: avail -18 -> 1483 mb, used 204 mb; ram: avail 2060 mb, used +1 -> 243 mb
'c 18-sep-2010 23:30:18.443;
help
