Pablo
That's right. but in this way I should always change the order of priority in setting "file placements > pre-document position"?? I did the necessary tests and I still have to use a manual system to make sure that sw goes fishing where I want, and not where he wants.. .the path where you stored the assemblies that can be the network when you work on the network or the local one when you work locally. in this way you guarantee the operation.
by giving the local network priority > I told myself: not finding the sw network goes to search locally, ok, but if I am in the office (connected to the network) and decide to work locally (e.g. for greater speed) I have to remember or to disconnect the network or to reverse the order in the setting, otherwise.... down salads of paths!
I would like to find a "switch" (like a macro) that would make this "inversion" of sectations without too much dismantling. .
