improvised closing autocad 2011 after a few seconds from start
  • Thread starter Thread starter fuser1982
fuser1982
Hello everyone!!! I have a problem with my 2011 32 autocad, when I go to start it after a few seconds it closes automatically, I tried to uninstall it and reinstall it but nothing fact, it always gives me the same problem. Does anyone know what it can depend on?
by a million factors!!! Maybe you should contact your dealer first. . .
I tried all the suggested solutions but, after an intense night and day of attempts, the result was always the same. I erased and rinse everything possible and imaginable but nothing done. I don't think it could be a license-related problem because ptima was working properly, the problems appeared when I had to replace the motherboard to the computer.
tried to update graphics card drivers?
inventor behaves like this when he doesn't find excel.
Maybe even autocad.
impossible, because I have the same identical programs as before.
the installed version is educational, so how do I contact the dealer, if I picked it directly from the autodesk site?
kind fuser,
if you have the titles (as a teacher, I presume) to download nothing less than autocad 2011 educational from the autodesk site, then you will have no problem getting a new activation code from autodesk itself.
I think the old code was "complete" to the old motherboard, but no longer (justly) to the new one: you have to contact autodesk in any way, explaining to him how things are without reticencies.
in my modest opinion, having uninstalled autocad has worsened things: before it should have exported the license by ltu.exe, and only after it should have been uninstalled. . .
Forgive me, where did you download the educational version? It's not like we're talking about a version.
quiet, tristan: let us 'u prufessuri ing.arch.fuser is appropriately justified.
I'm just saying, egregio prof, that in this noble forum there are no people with the ring to the nose or the alarm to the neck, so be honest. without if and without...
kind fuser,
We put the dots on the i.instead of doing so much sborons, and making out about the origin of the version and what else said in previous posts, you should know that the autodesk did a Convention with different Italian universities and educational institutions so that both students and teachers can use these software for educational purposes.
closed this parentheses, I wanted to communicate that the problem was related to the motherboard in fact, after having ascertained that the incomod was not due to harware incompatibility, I contacted who of duty and provided to assign a new License
Good boy! I know very well, but you didn't answer my question anyway! for your info Italy has a retailer of edu products (small n.d.a.) and for any problem you can address to them, if the problem is related to educational versions. I don't make the cum, and always for your info I've been working in the channel for many years.
So what? you changed the motherboard and everything worked out? Good for you
the problem was tied to the motherboard ... I contacted who of duty and provided to assign a new License
..that is, just as suggested by this 'short' this morning at 7:35 (second paragraph).
instead of insulting, he would have made better figure thank you who lost 3 minutes of his existence, trying to help her. . .
:36_1_10:
not from any error code?
Hello I am new to the forum I found you because I searched on google how to solve the problem that the author of the topic....
I have the same problem but with autocad 2012 32bit the program starts for a few seconds and then disappears .... to make you understand better I created a gif to show you:
I found an error log file in the files that says:
HTML:
errore irreversibile:  unhandled access violation reading 0x0020 exception at 128b9f3h
01/05/2012 at 13:58:44.513  disegno:
but it probably created because I used the autocad program to restore default settings to help me! !
thanks in advance :smile:
