jim78b
How do I put the image in autocad le do of my dimensions and autocad keeps the proportions there is no way to change to that?
No. possibly try to create a block with the image itself; is the only way in autocad to scale not evenly entitiesHow do I put the image in autocad le do of my dimensions and autocad keeps the proportions there is no way to change to that?
right, even if it does first to climb externally to e.g. with irfanview (command ctrl-r).possibly try to create a block with the image itself
Tristan,is the only way in autocad to scale not evenly entities
I should do it with at least 10000 people. ..exist a forum for this kind of requests:Tristan,
Since you "note in the channel", I ask you a courtesy.
You could write 2 lines to whom you have to, asking to apply the _stretch command to the bitmaps.. ?
It is in fact absurd that even the derelict wordpad manages to iron an image, and not his autocad majesty (apart from map that does it normally).
Thanks![]()
I understand, but as long as I hang (that I'm no one) my request in that wish-list, instantly slam it at the bottom according to the lilo rule...there is a forum for this kind of request
it doesn't work that way but I can try :wink:tentar non nuoce!
...the great is your reward in heaven. .5,1-12a:3513:posso provare :wink:
