resize images
jim78b
How do I put the image in autocad le do of my dimensions and autocad keeps the proportions there is no way to change to that?
No. possibly try to create a block with the image itself; is the only way in autocad to scale not evenly entities
right, even if it does first to climb externally to e.g. with irfanview (command ctrl-r).
By doing so, you can import it in autocad without going crazy with x,y scale factors of uneven blocks.
Tristan,
Since you "note in the channel", I ask you a courtesy.
You could write 2 lines to whom you have to, asking to apply the _stretch command to the bitmaps.. ?
It is in fact absurd that even the derelict wordpad manages to iron an image, and not his autocad majesty (apart from map that does it normally).
Tristan,
I should do it with at least 10000 people. ..exist a forum for this kind of requests:
http://www.augi.com/home/default.asp
there is a forum for this kind of request
I understand, but as long as I hang (that I'm no one) my request in that wish-list, instantly slam it at the bottom according to the lilo rule...
if instead the post-it is put by a Mr. var like you, by default the lifo rule applies (last in first out). .
Try not to harm!
