post processor visi 15 haas automation vf
  • Thread starter Thread starter neverste
neverste
Good morning to all, I just signed up and used just visi15 of the truth to perform work on the work center haas automation vf 3 axes.
I wanted to hope if it was possible to recover files to postprocess paths on this type of control? Thank you all!
hi, it depends on which language you have to recover files. if you mean you have dwg/dxfs typical of autocad, in visi you have to import them with the appropriate command of the file menu ( visi has a proprietary format ).
If you mean instead that you already have block/cn files written for another machine there should still be a revpost utility to recover or as geometry or as a tool path your old cn files, but I think you will have to take it from your dealer. I say it should because the visi is at v18.
Say hi.
Say hi.
I am not very experienced but I think I have recovered the file! anyway thank you.. .
