end of race
  • Thread starter Thread starter nicolapastena
nicolapastena
I put a model in a simplistic way, since there is nothing about the help, in practice I have a cylindrical fixed cable casing (which is a guide) and internally I have placed another cylinder (concentric) the problem is that I can't understand how to define the two lines between the fixed and the mobile piece to prevent the connection of the two solids.
thanks in advance for the answers I place the file
or check it with this, or put in the table and quoti in section.
mike you could show me about the model I sent you cm you do because I can't do it
in the help says soltato how to do to detect an interference but not how to define an end run, excuse me but I just can't understand cm I have to do to solve this problem
You're right, in the late afternoon I'm a bit fused... Imagine the evening...:biggrin:
you have to use the couplings, test coupling limit distance, look below
advanced couplings, should be
the most suitable.. .
I'll get you the file.
search the "limit couplings" guide you will see that you can set a race with a minimum limit and a maximum.
practically pair two faces that have to beat giving it 0 as a minimum and running length as maximum.
