Richart
hi guys, I made the set of a counter pin with a "hand crank to elbow" now I should be able to pierce the crank pin like the photo, but I can't because sw doesn't recognize me that part like a surface or plan. I also can't use simulationxpress because the function is not supported overall, while in the part it does not recognize any solid element.
I attach the set, the part created by the set, and the photo of how the hole should be created.
appearance your clarifications and
thank you all in advance!
p.s. why is there always a visible sketch in the axieme?
