win7 64bit e anteprima file cv5
stef_design
Hey, guys.
I went to win 7 pro 64bit. with catia v5 r20 sometimes I see file previews and others no. on what depends?
this on 3 machines, while first with win xp 64bit the problem was not there.
I have no win7 pro 64b but could it be that those files you see were opened and saved under r20 at least once?
Yes, in fact if you open the files you do not see and save them with r20 then the preview appears. but when you restart the pc the situation changes; previews disappear again.
I think it's an incompatibility between cv5 sp4 and win 7 pro.
I am curious though to know if other users, with win 7, find the same problem.
Hi:
Okay, at least we have a tip.
Now try with catdua maybe you never know....
Nothing, even with the catdua does not flee.
possible that no one uses win7 64bit with cat? :confused:
(now win7 has been out for about 2 years)
Greetings to all... .
It's a little bit that you don't feel...
I open only one bracket to chedere a stef (apart from previews) if for the rest it is ok with the win 7......
I ask this xche or took a pc and I wanted to load it and make it pio to see my new employers.
greetings to all
greetings to all
you for the rest everything ok, also the performances are improved (especially in win7 64bit).
But the preview bug is really frustrating.
we have all the encoded files and therefore it is difficult to remember the codes by memory: mad: the previews helped a lot.
I installed caia last night and also to me from the same problem... .
probably will fix it with the next sp.
Hello and thank you
Hello and thank you
Of course ds sleep. could control compatibiities with win7 before releasing r20.ciao
catia r 20 sp1 suitable several months ago from r 19.
I can't say for sure, as I've noticed only recently, if in conjunction with the upgrade or after, the previews of the files in window xp sp3 no longer appear. autocad previews and others, photos, documents etc. appear regularly. I only remember that for a period the previews appeared even if in very slow progression.
also to myself with r20 and sp4 both win xp 64bit and win 7 64bit.
It's a break.
Can you solve the problem?
reply received by ferdo on other forums:
restore icons as preview in window xphttp://www.edstechnologies.com/mailer/jan09/tips-tricks.htm
the specific commands, to be issued in a command prompt window, are:
1. point to the cnext.exe file:
cd c:\program files\dassault systemes\bxx\intel_a\code\bin
where xx refers to the catia v5 release leve to be used.
2. run cnext with the /regserver option
cnext /regserver
the cnext /regserver command is documented in the infrastructure portion of the catia v5 online documentation, in a section entitled "installing multiple versions of version 5 on the same computer".
cnext /regserver
Did it work with you, Marco?
I think it's not about win7, but it's a generic procedure for catia.
After hitting me with the correct spelling of the command, the previews are reappeared. phenomenal! ! !
the command is certainly worth for xp 32 and 64 is not for seven.
but attention to \ and / spelling as follows
c:\programmes\dassault systemes\b20\intel_a\code\bin\cnext/regserver
Hello, Marco, can you explain the procedure better?
the string 'c:\programs\dassault systemes\b20\intel_a\code\bin\cnext/regserver' where I insert it?
Still do this:
in the window type cd.. enter until you get
c:
then type
cd\programmes\dassault systemes\b20\intel_a\code\bin enter
you will come a line
c:\programmes\dassault systemes\b20\intel_a\code\bin >_
now type below cnext/regserver enter
done, close and check
