Yes, in fact if you open the files you do not see and save them with r20 then the preview appears. but when you restart the pc the situation changes; previews disappear again.I have no win7 pro 64b but could it be that those files you see were opened and saved under r20 at least once?
Nothing, even with the catdua does not flee.Okay, at least we have a tip.
Now try with catdua maybe you never know....
you for the rest everything ok, also the performances are improved (especially in win7 64bit).I open only one bracket to chedere a stef (apart from previews) if for the rest it is ok with the win 7......
I ask this xche or took a pc and I wanted to load it and make it pio to see my new employers.
greetings to all
Of course ds sleep. could control compatibiities with win7 before releasing r20.ciaoI installed caia last night and also to me from the same problem... .
probably will fix it with the next sp.
Hello and thank you
also to myself with r20 and sp4 both win xp 64bit and win 7 64bit.catia r 20 sp1 suitable several months ago from r 19.
I can't say for sure, as I've noticed only recently, if in conjunction with the upgrade or after, the previews of the files in window xp sp3 no longer appear. autocad previews and others, photos, documents etc. appear regularly. I only remember that for a period the previews appeared even if in very slow progression.
Did it work with you, Marco?reply received by ferdo on other forums:
restore icons as preview in window xphttp://www.edstechnologies.com/mailer/jan09/tips-tricks.htm
the specific commands, to be issued in a command prompt window, are:
1. point to the cnext.exe file:
cd c:\program files\dassault systemes\bxx\intel_a\code\bin
where xx refers to the catia v5 release leve to be used.
2. run cnext with the /regserver option
cnext /regserver
the cnext /regserver command is documented in the infrastructure portion of the catia v5 online documentation, in a section entitled "installing multiple versions of version 5 on the same computer".
Hello, Marco, can you explain the procedure better?After hitting me with the correct spelling of the command, the previews are reappeared. phenomenal! ! !
the command is certainly worth for xp 32 and 64 is not for seven.
but attention to \ and / spelling as follows
c:\programmes\dassault systemes\b20\intel_a\code\bin\cnext/regserver
Okay, so just type in dos:cd c:\programmi\dassault systemes\b20\intel_a\code\bin\cnext/regserveronce I send what happens?depends on how you open your command prompt located in:
start - programs - accessories- command prompt
look at these instructions on dos commandshttp://www.c3scripts.com/tutorials/msdos/cd.html
marco
