stef_design
if nothing happens is ok
close and check
chiudo win o catia?
close and check
attention cd stands for change directory and then changes the directory (folder) in which you are at that moment... once entered the appropriate folder c:\programs\dassault systemes\b20\intel_a\code\bin then type the command you need to run cnext/regserverOkay, so just type in dos:cd c:\programmi\dassault systemes\b20\intel_a\code\bin\cnext/regserveronce I send what happens?
it's true. it works. tried on win xp 64.correct procedure:
type
cd\
come on.
c:
type
cd programs\dassault systemes\b20\intel_a\code\bin enter
come on.
c:\programmes\dassault systemes\b20\intel_a\code\bin>_
type
cnext/regserver enter
if you don't appear strange messages is done, then close.
mar
I also like "setf_design" I have this annoying problem with the previews of the v5 cat files in win7 64bit. I tried to launch the command string but the result is not the one hoped: the first time I access a directory containing the files I see correctly the previews (directory located on the server), but then if I go out and return to the same directory the previews are no longer seen. I tried to restart the pc, rehale the command string, but nothing to do!! !
the same thing happens if I take the same files and cover them on the local disk. . .
I looked a bit on the internet but it seems that the only discussion about it is this... it seems very strange to me that no one using windows 7 does not have the same problem.. .
This is very frustrating! ! ! !
p.s. with xp 64bit everything works perfectly
be careful when you type in cnext/regserver command because the folder of the prograama in win7 is differentI have exactly the same problem as described by blond.
I think someone should put the problem to dassault.
Hello, thank you for your answer. as soon as I read the post I immediately tried to perform the new string and with great surprise I noticed that the previews were correctly seen!!! even if I changed directories and then I returned the previews they saw equally. ..fantasy!!! :biggrin:be careful when you type in cnext/regserver command because the folder of the prograama in win7 is different
type
cd\
Come on.
c:
type
cd c:\program files\dassault systemes\b20\win_b64\code\bin enter
Come on.
c:\program files\dassault systemes\b20\win_b64\code\bin>_
type
cnext /regserver enter
so check to be in the right position, and that between the / and cnext there is a space.
I don't understand anything. do you have win 7 with cv5 r20?I think the problem is your computer!! :biggrin: pass me the line!
normally the disappearance of the icons happens when you have one or more realized of catia and you disconnect one leaving the newest, so surely the solution could be to remove and reinstall the realized of caia that you have now.
When you want to do this, make sure that when you launch the cnext \regserver command, your system is in administrator mode, I noticed that the win 7 security limiter greatly limits the execution of commands.
So... just to shed light on our situation:si e a 64 bit
spk 4.What do you have?
try to run the command prompt as administrator. ..nothing to do...the previews are only seen the first time then disappear.What do you have?
I would investigate a bit about how the installation of the operating system of the machines has been made, because I feel that many filters have been inserted, which blink the correct loading of the casket, forward the fact that you are administrator of your machine does not exclude that the system does not block the execution of the executable.
in win7 you will notice that by tastdx on an application tovi the command "start as administrator".
I would see in detail how those who prepared your pcs installed the win7, and what degree of protection it provided.
ps excuse the question but what does peldom mean?
with what realization catia have the server files been created? I don't have any difficulty starting with the r18.try to run the command prompt as administrator. ..nothing to do...the previews are only seen the first time then disappear.
to make you understand a little how messed up is the speech I performed the following operations:
1)opens a directory on the server where you do not see previews (in no display type, e.g. large icons, small, etc.)
2) copied the aforementioned local directory and set the display in "big icons": previews can be seen correctly
3)close and open the local directory: previews can be seen correctly
4)Add local directory with f5: previews can be seen correctly
5)changed the local directory viasualization from "big icons" to "small icons" : the previews are no longer seen, even returning to the previous configuration
as described above the problem is quite complex, previews are displayed at random, whether you work locally that you work at sever (in our case with windows server 2003). I wondered: how does the win7 previews handle? use the thumbs file as xp? Why sometimes I show them and sometimes not???
p.s. peldom
What do you mean?with what realization catia have the server files been created? I don't have any difficulty starting with the r18.
Also I cannot simulate this situation, you should try in a machine with xp to create a folder with one or more cat files and through the property panel, make them in "read only" (the single file not the folder, after which transposed the folder into the new machines.
the same type of test I would also do it through the server.
