two graphics cards on the pc
  • Thread starter Thread starter Alex_vr-46
returning to the sli configuration (parlo di nvidia Framework): should you use only one more powerful card or 2 less powerful cards but in parallel?
For example: better a 4000 picture or two 2000 framework in sli?
the sli does not need, if not with a few compatible software.
qui the page nvidia... will not be very up-to-date, but I do not think the number of applications available have increased. . .
makes "strange", for example, that for a software like 3ds max, widespread and supported by drivers since the times of the elusive glory, it has never been implemented the sli... I'm not saying it would be a killer application, but it would give a good incentive to buy a picture...
without talking about other soft even more widespread, autocad in primis...
No, unfortunately I haven't solved this yet... :-)
Try again.
remove everything, uninstall all the drivers (first download from the swx site what you need, save it in a folder without installing it) and make sure they don't leave "code" around with a nice cleanup of the registry (there are free softwares appropriate to clean up from the video drivers. . driver cleaner pro I use it and do its duty).
restart to terminate the procedure correctly.
turn it off, remove power, physically remove it and put the card back. turn on and windows will open in vga mode (you see badly and off resolution), find the new tab and try to start automatic installation; Don't let him do it, cancel the trial. install the driver you previously downloaded and saved, go to that folder and start the executable. should do everything by yourself, only answer yes when he asks and eventually will restart you. should turn on already in the correct mode/resolution, at the limit you can enter the control panel of the board to set it to your liking (you can choose solidworks for the program settings).
I always do this and it all works at first.
Marco:smile:
Try again.
Marco:smile:
Thank you....Just I can try to remake everything with the procedure you say....in the meantime I immediately unload the program for cleaning the drivers and that on the site swx....
one thing... you think I better connect the card to the monitor with normal dv cable instead of the hdmi? ?
I'll try to see if anything changes... .
I will keep you updated...
Thank you. .
at the limit you could try a ubuntu live distro and if the view is good see that resolution adopted
Try again.
Marco:smile:
Sorry if I break you again....I searched for driver cleaner.......but I only find it in old versions for windows xp or 2000......you have a link for a more updated version.... thank you very much
I find it only in old versions for windows xp or 2000......you have a link for a more updated version.... thanks a thousand
I didn't tell you, because here I have win xp.
the last version seems to me is the 1.5 and works for all windows platforms. download it and install it equally with win 7 should work.
this one of the many places where you find it: http://www.filecluster.com/system-utilities/system-maintenance/download-driver-cleaner-net.htmlHello
marco
live distro type ubuntu? ? ?
Sorry about ignorance, but what is it? ? ?
practically a live distro is an operating system that works by cd using ram without writing anything on the hard drive (actually you do not risk damaging windows or the operating system you have on the hard drive)) you download from here the iso http://www.ubuntu-it.org/scopri-ubuntu/download mastery on a cd with black (or another proramma to burn) then boot with the cd inserted then you appear a menu , go on ubuntu test choose the language and you start the live , at the end when you got tired of using it, you usually go out with windows remove the cd and everything comes back as before
I changed the cable... it's okay.... I can't use that hdmi but only the dvi.... even if it seems strange to me....mah.....
I was disappointed... possible that there is practically no difference on the fluidity between the geforce 460 and the 2000 picture?
the only thing is the painting warms less.....
tried on a video game the geforce is clearly superior.... on solid instead I do not see differences......mah
I've never been able to try a real picture that isn't a low profile and they were always worth enough and I've always wondered: what's the difference between a chalk and a painting apart from stealing money? Perhaps the 3000 euro picture really goes more than the chalk.
until you could have hacked geforce in the picture and really go a lot so optimized, especially as fluidity.
It's a businnes like everything knows....
This time I got screwed...... if anyone cares about a 2000 painting from 1gb...... well....contact me.....
to 50 euros... obviously hahahahahahaha :biggrin:
Anyway, try overclocking her. as it heats less you can push it to the maximum of its architecture;)
If you don't know how to overcycle it I assume that you haven't even configured the drivers to turn that 2000 picture card. to overclock it, mount the slot card. install the nvidia picture drivers, open the panel and scroll in half that there is the management process frequency and ram of the card and management fan... from the parameters. or do the autotest with fine optimization....it takes a lot of hours. then in the 3d program tab you should configure all the graphical parameters for the modelers you use.
the video card is not like an electrodomestic that puts the plug and lazy on:biggrin::biggrin:
ah well...in the nvidia panel this already "pocciato"...... are not at the levels of: it miserves a keyboard with a green button to turn on and a red to turn off......
the drivers I downloaded and installed those of the site of solidworks.. . .
