change tilt structure
  • Thread starter Thread starter Erikilrosso
Erikilrosso
Hello everyone,
I have created a subtle conceptual mass using the vertical plane, (support for a bridge that I will have to repeat n times) now I am having to tilt some degrees the element obtained, turning it along its larger base. the wheel command has no effect, so I have inserted a tilted plane with the base coincident with the vertical one on which it supports the element, trying to "copy" my element on the new plane, but I can't come to the end. Where am I wrong?
thanks:redface:
... in theory the procedure is correct (copying only the element), in the "practice" if the element is somehow bound to the pv (luquets, dots, quotas, etc.) or to other pieces of the silhouette are "legated" or "dependent" to other reference planes, there are definitely problems.
... we must see how the family is built...
... try to nidify the first mass (family) in a second mass family on a plan (prepared suit) that "route". . .
Sorry I'm late, but we had a contest to deliver.
I solved the problem by setting up a tilted vertical plane of what I needed and doing the mass leaning on this plane.
the next problem was that I should have rotated the mass contained in the sloping plane around a perpendicular axis to the vertical plane (not to the mass) passing through the greater base of the mass, after some attempts I succeeded. revit for these measures is not very flexible. I would like to attach an image of the result obtained but I have not yet understood how to do it.
If you put the faces you are already halfway
if you descend lower than the faces there is management attached
and from there it is made:finger:
right, but normally I use the "fast response" and all those commands do not appear.
I also found that, as a contest, I could not publish images before the deadline and publication.
even if you make quick response under the window you always have the button go in advanced mode
Do you also take care of military bases?
conversion of the base of the maddalena?
No, it's the new base for atomic submarines here in aosta! You know, you never know...
with the water coming down would also be a feasible thing! !
small o.t.:
Are you from aosta?? Maybe we know each other... .
I sent you months ago a private message but you never answered me:
Yeah, Captain Harlock didn't think about it. ! !
I can't tell you I don't know where the messages are!! It would cost me a dick to make54.:biggrin:
on top of the page cad3d a dx under "welcome, erikilrosso"
but perhaps with an eye only you will be missed:tongue::36_1_14:
