Erikilrosso
Hello everyone,
I have created a subtle conceptual mass using the vertical plane, (support for a bridge that I will have to repeat n times) now I am having to tilt some degrees the element obtained, turning it along its larger base. the wheel command has no effect, so I have inserted a tilted plane with the base coincident with the vertical one on which it supports the element, trying to "copy" my element on the new plane, but I can't come to the end. Where am I wrong?
thanks:redface:
thanks:redface:
