doc83
Hello everyone!! I press that I use solidworks from 1 bear, and it is not my field (study medicine but I have the passion of mechanics/cnc, etc.)...
I come to this point: I'm creating a sheet for a box that I need to contain some pcb that I did... mobile, basically!
1. drawing with the "scratch" the furniture seen from the right side, performing the intelligent quotation for the size.
2. I extrude the sketch and get a solid, I do not remember with what function I "cut the side" and given 2mm thick to the sheet (which will be the millimetre thick of the aluminum plate in my possession, which then I will feed to the cnc for drilling). . .
3. I generate the sheet from the solid, therefore itorno on the sketch, I create the ribs/astes and I make the fan through the appropriate function. . .
everything ok, but when I go back from the bending, to review the solid with the beautiful and made fan, the latter disappears as it is "staged on the same floor" on which he lay before... I mean if they select from the left the fan, I see the sketch that is located at the point where before there was the face on which it was housed, and that now it is folded (and then lies on the vertical plane).... I also tried to make holes, but the situation is the same....
how can I "unite" the fan so that it is solid to the sheet even after bending? fat to all boys! :
p.s: the search function is still hostile to me, because I do not know well what keywords to insert in order to carry out a targeted research, excuse me if the question has already been posted! :
