xxfast
Sorry, but I never happened. . .
if I create parts with sw 2011 then I can open them from another pc with sw 2008
if I create parts with sw 2011 then I can open them from another pc with sw 2008![]()
you can not do with any parametric cad3d on the market.No! compatibility is open a file created with prehistoric version with future version program. not the opposite.
in fact it is not a 3d parametricI wanted to be sure.
with autocad 2011, for example, I can save the file in the previous version and then open it with the older version.
and no, maybe.:biggrin:But if I save in .step or :iges and then open with sw I should also find the functions?
try to save a cube in step, reopen it with swx and check so alone how much you ask seems too difficult?But if I save in .step or :iges and then open with sw I should also find the functions?
Okay, I get it.and no, maybe.:biggrin:
you have "imported races" without history functions etc., "mothers", end to yourself.
if it was a joint neither constraints and relationships, all mobile bodies.
However, if you save and reopen in different versions of swx use the parasolid that is its kernel. should possibly be easier to recognize bodies, surfaces and "some" function with the appropriate utility.
iges no absolutely, is what gives more problems (then it is more dedicated to surfaces).
p.s. and we no longer compare with autocad, are 2 worlds completely different. using both of them you should know.
and if you do a search back in the forum you will find hundreds of threads on the topic "Save back" and retrocompatibility.. I was saying that the stones also know it (besides it is well explained in the first paragraphs of the guide/presentation of the program).
