Peppe
finally we're discarding e vediamo.....
I confirm, it does to me even if I have to bind, at the time of the selection of the axis you see only the extreme points but not the axis....with the sp1 to me disappeared preview of the axles when I have to project them, you see only the extreme points but not the axes. fx 1800 drivers are up to date.
Does anyone else have the same problem?
Finally! ! !
this sp has solved a problem on the interface of choice of faces with constraints.
unless they've "come" something else seems to be okay
in fact, they fixed something and bought something else...I confirm, it does to me even if I have to bind, at the time of the selection of the axis you see only the extreme points but not the axis....
