Unasseen per andni sketch?
  • Thread starter Thread starter Trotto@81
Trotto@81
I have been using pro engineer wf3 recently, I have been coming from years of autocad, so I have to detoxify, it is not immediate I can assure you, as I assure you that I have used the research and I have found nothing about it.
If in a first sketch I define certain axes of symmetry does not make me use the same axes for a second sketch, forcing me to recreate others on it, is it normal or did I not understand anything?
that I know you cannot reuse the symmetry axes of a previous sketch, even if I expect to be promptly denied. however, they are invisible outside the sketch itself and therefore do not weigh the display.
I find myself so well with proes that I'm about to draw only when I put constraints not when I pull lines. I'm a restraint maniac. The only one who doesn't attract me is the double one.
you have corrected what says mad76, only from the wf5 onwards you can create a sketch with a particular axis of half-carry that you also see outside as an axis.
to see clearly understood the use of a same axis in different sketches, right?
I didn't know that, but I tried and looked for the guide ... I can't use it.
Will it be old age?
the axis can only be used as a unique reference for the geometries of revolution, not to reuse it at a symmetric level.
in the wf5 they introduced the axis and geometric points but I think that trotto always wants to reuse the same reference axis for the symmetric quotation.
This is not feasible, the axis of symmetry must always be recreated.
Okay... I feel a little less comfortable.
I explained perhaps wrongly, in wf5 the axes of half-way geometry can be seen outside as axes and can be taken as a reference in other sketches, on this reference it is then possible to build other axes of half-carry.
I imagined, I had understood your reasoning well, I only added the clarification not to waste time at that maxopus fennel. :-)
exactly, because in autocad I was used to use the same "axis" for all I needed, for example solids of revolution or extrusions, although in reality in the program of the autodesk the axis is simply a line.
I noticed and always working in autocad is making things difficult, and then the 3d in pro engineer is a mug compared to the mortal jumps I had to do first to realize things slightly elaborate.
