Giovannino60
I autocad on two pcs on one I built myself with work area/personalize my toolbar as you do to export bar of the 2010 autocad tools on another pc with autocad 2010.
dwt does not contemplate customization of the user interface ( fortunately!)open autocad with the work area that interests you, save a dwt file and use it as a default model on the other pc.
_wssettingsBy the way. Does anyone know why when I change the work area when I return to my personalised, I have to put all the boxes back in place?
even if it is not recommended to put automatic rescue._wssettings
in the box that appears imposed "automatically saves changes to the work area"
quoton, "knowing" changes can always be saved.even if it is not recommended to put automatic rescue.
I agree with you. call it "solution for the most lazy" :biggrin:quoton, "knowing" changes can always be saved.
with the disadvantage that then employ twice the time to repair the eventual "damage" done. :biggrin:I agree with you. call it "solution for the most lazy" :biggrin:
Well, it is not said that there is automatically damage. .with the disadvantage that then employ twice the time to repair the eventual "damage" done. :biggrin:
how do you save a dwt file and how do you do it from the other pc to import it?open autocad with the work area that interests you, save a dwt file and use it as a default model on the other pc.
you have already been explained before how to save the work area and all its settings:....I wonder if you can only save the work area.
I did so:
on the first pc with the work area, I did save with file name .dwt, this file I opened it on the 2nd pc but the work area of the 1st pc did not open.
dwt is a file "prototype" (or model) and does not take you behind the info on the interface!Of course you're hot, huh? !dwt does not contemplate customization of the user interface ( fortunately!)
you do not read what is indicated to you!I did so:
