reggio
Good morning to all, I apologize if I write in the wrong place, but this morning I am in emergency with a problem of which I difficult to identify the origin.. .
What happened on my colleague's pc: just arrived this morning launched solidworks that opened without problems, then launched autocad2010 that gave him irreversible error (unfortunately he did not mark the error code) then autocad closed and immediately after that. . .
- links icons (only those related to links, because icons related to desktop files have not undergone modifications) have stopped working while maintaining the link within the correct "properties", they took as an icon image that of autocad and the description added the extension ".lnk", in addition to the links icons on the desktop, they also made the same end:
- all icons on the application bar
- all icons inside start and start/programs
links no longer work if the address inside the icons is still correct, to open the programs you have to go in c:\programs\...\*.exe, or double clik on a file.. .
Unfortunately also re-creating links, icons are always autocad (also for links of other programs), links inside are correct but do not work
we noticed that within "preferred" resource explorers are missing links to desktops and other folders. . seems almost that the problem lies from those parts, or cmq in that pc because if you go to the various folders of the server, all the icons are in place and obviously the files open with double click... .
Could you help me understand what happened and fix things?
