why does this neon not emit light?
reggio
Hello, would you tell me why this neon does not emit the blue light I set from the center of the neon to the outside?
I don't open the annex. Did you insert it? I ask you why the system these days makes the bizzes to fit them. .
Okay, thanks sampom!
I report the problem on the thread dedicated to attachments! !
(I open it and I find myself three rar: neon-1.zip neon-2.zip neon-3.zip and now that I have tried and clicked on the singles makes me "zompare" from one rar to another!)
Is that what you wanted to get? :NEON BLU.webpto show it you have to activate realview(at least, I from your file did nothing but that).
but in order to do it you must have certified opengl graphics card (envidia quadrifx or ati firegl).
Is that what you wanted to get? :View attachment 12883to show it you have to activate realview(at least, I from your file did nothing but that).
hi, I would say yes, in practice now I have to put it inside a sheet box on which I practiced a spacing based on a text (logue) and I wanted to see the light effect coming out of the box. .
in my pc I don't have such cards, but I expected that at least in rendering I would show it... :
keep in mind that they are not rare tabs and necessarily very expensive. a 580 picture costs around 200 euros, while one 1800 over 450.
in search I found this old post that treats my problem a bit, graphics card I have a picture 1800, yet I try to insert led appearance or manually put a color and going to change in color settings the voice brightness, but it does not give me any light effect of the neon that I would like in solidworks or rendering. I wanted to know if anyone can help me thank you.
change the light intensity, parts from 30.00 w/srm^2.
I'm sorry, but I didn't see this discussion. . .
I don't know if you've solved (commit no... :biggrin:) but this is what
You want to get?
for the record, not even with the real view activated you see light shining, you see it only in rendering, as well as in preview.
You want to get?
I put 100 as a value of brightness, but in rendering I don't see it anyway... Do I have a problem? ?
I know, I say you neglect me... ;
I don't know if he's solved (I bet not... :biggrin:) but that's what you wanted to get??
You wanted something like that?
(fast/mike- yes I wanted something like this)...but then you provoke me, huh? but then my efforts not to intervene until I had responded tolast my request :redface: They're not appreciated, huh? ... but then I have to start, huh?
I admit it...I couldn't. :frown: ... but only because the indications were not accurate... at the millimeter...
So now... explain to me where the hell I come from "change the light intensity, parts from 30.00 w/srm^2".
Can you post the file?
... nò post the files of the examples I say it!!! Is it not possible that you always lay the stone and then hide your hand? Please. .
so in the meantime I try to cuff and repeat the vs result... Then I will try to apply it to mine, as you see in the image, the neon would be to be placed inside a case of sheet and opaline (lexan semi-transparent), with swx I would have wanted to give a realistic idea of the finished result....
... and now, below with vs 2011 files (and precise indications) :biggrin:
begins to set a suitable environment, dark black.
then lighten the shades of blue, logical that if you put too dark
He will not illuminate anything, as in relalty.
how counterproof you can give a clear color and see that actually
It lights up.
Try and tell me.
It lights up.
Try and tell me.
look I gave you a fast file to see the problem, but I have already tried to put it in a dark dark environment pesto and with white light, me the result is that I see the body of color, but I do not see effect of the light that propagates in the environment, soppratutto that touches the other surfaces, mintra I clearly remember that in the 2010 version I could, even in 2011 before the passage to windows 7.
