yag
Hello I have a problem every time from autocad I print a dwg the print in the pdf rotated as never?
never happened...maybe if you give us some more info! We don't have the crystal ball.Hello I have a problem every time from autocad I print a dwg the print in the pdf rotated as never?
in practice I open the dwg I go on print and put cme printer adobe pdf but it does it even if I put dwg to pdf native autocad then I go on print imposed all the orientation but it is printed rotatednever happened...maybe if you give us some more info! We don't have the crystal ball.
no even in pdf design is rotated without side bandsbut it's a moment....
within the sheet the orientation is correct? ? ? ?
I mean,
your design is so, oriented "landscape"
_
| xxxxxxxxxx
| xxxxxxxxxxxx
_
________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
you print it in pdf and say to see it rotated by 90° (portrait)
now, in pdf you will see the sheet with inside the drawing
do you see both rotated (portit) or see the portrait sheet with landscape design (and then blank bands above and below)?? ? ?
ok I understood the print is correct but the pdf exhibition rotated... perfect but there is no solution to have a pdf of a dwg file that is rotated?print your drawing on paper
if you put it horizontally oriented, you see it correctly
if you take the same design and turn it 90°, you see it "wrong", but the design is to all effects printed correctly. simply your display is wrong.
I know that program does.... But I wanted to do it automatically... .probably adobe acrobat (not to be confused with adobe reader) can allow you to turn it (besides many other options)
