stampa pdf ruotata
  • Thread starter Thread starter yag
yag
Hello I have a problem every time from autocad I print a dwg the print in the pdf rotated as never?
never happened...maybe if you give us some more info! We don't have the crystal ball.
in practice I open the dwg I go on print and put cme printer adobe pdf but it does it even if I put dwg to pdf native autocad then I go on print imposed all the orientation but it is printed rotated
type in autocad I have a line like this:
in pdf is what:
Do you understand?
but it's a moment....
within the sheet the orientation is correct? ? ? ?
I mean,
your design is so, oriented "landscape"
_
| xxxxxxxxxx
| xxxxxxxxxxxx
_
________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
you print it in pdf and say to see it rotated by 90° (portrait)
now, in pdf you will see the sheet with inside the drawing
do you see both rotated (portit) or see the portrait sheet with landscape design (and then blank bands above and below)?? ? ?
I mean,
_
| xxxxxxxxxx
| xxxxxxxxxxxx
_
no even in pdf design is rotated without side bands
is not a problem of autocad, in adobe reader the pdf is always rotated vertically whatever the original rotation.
you just have to turn the view: mausc+ctrl+more/maiusc+ctrl+ less
is not printed rotated, but View view rotated.
if you enter the pdf in the dwg you notice that the print is ok.
It's like painting a landscape on a canvas rectangular horizontal post and then attach it to the wall in vertical. :tongue::smile:
print your drawing on paper
if you put it horizontally oriented, you see it correctly
if you take the same design and turn it 90°, you see it "wrong", but the design is to all effects printed correctly. simply your display is wrong.
ok I understood the print is correct but the pdf exhibition rotated... perfect but there is no solution to have a pdf of a dwg file that is rotated?
with a0 format? I noticed that it does not with all formats but only with that a0
probably adobe acrobat (not to be confused with adobe reader) can allow you to turn it (besides many other options)
