gianmauro
Hello, everyone. it happens to me that with autocad 2010 I cover an object and when with dx key I look for "paste as block" these is present but not selectable. Has anyone ever ceased?
In any case, I agree with tristan... it is best to invest in a day of lower productivity to learn how to use ribbons... I also find them comfortable after twenty years of autocad use.in my office there are some users who have learned to use autocad about ten years ago, do not use ribbons
no variable to set.happens after some glue as lock and always on the same machine.....maybe it is an installation problem. ......... .
Sure I would like to understand the problem, probably some variables to set up.
is full of software that use .net 4 with ribbons!but what ribbon is enough that microsoft put that crap on office, the only one who copied it as style was the autodesk
Do you make examples? ?is full of software that use .net 4 with ribbons!
beh........per esempio. . . ....Do you make examples? ?
without being obliged to the ribbons,in my office there are some users who have learned to use autocad about ten years ago, do not use ribbons
that is the simplest solution :finger:without being obliged to the ribbons,
can use the keyboard :
ctrl+shift+v
if anything the opposite if one does not know things must ask.. I asked!! and you did the examples simply....if you don't know, please shut up!
in your speech you didn't ask but you said that "the only one who copied it as style (the ui ribbon) was the autodesk". Anyway, you asked and I answered. You learned something new today....the only one who copied it as style was the autodesk
activate paste menu item as blockHello, everyone. it happens to me that with autocad 2010 I cover an object and when with dx key I look for "paste as block" these is present but not selectable. Has anyone ever ceased?
