"paste as block" not selectable in autocad 2010
  • Thread starter Thread starter gianmauro
gianmauro
Hello, everyone. it happens to me that with autocad 2010 I cover an object and when with dx key I look for "paste as block" these is present but not selectable. Has anyone ever ceased?
Thanks for the tip.
But if it's such a big hole, shouldn't they have made a hotfix?
in my office there are some users who have learned to use autocad about ten years ago, do not use ribbons (which surely uses who has just started and if you find them by default in the first seen)
autocad use for almost 20 years and I find the ribbon formidable. my advice is: use it!
you can also copy the items of the object normally and then select them all and create a block!
I, frankly, never happened a case like this... When do you happen?
In any case, I agree with tristan... it is best to invest in a day of lower productivity to learn how to use ribbons... I also find them comfortable after twenty years of autocad use.
Besides, I would add, that if after years of use you still do not use the commands by keyboard, it is time that you start also with these...
usually the most used commands are always those... those that are used less are found on the ribbons or on the tool/menu bars (which still exist).
I repeat, just lose a couple of hours to customise the interface, and productivity increases exponentially (almost).
use a cad, which is a work tool, involves not only pull lines, but also optimize its working environment... It would be as if a f1 driver didn't know what it entails regular flap and engine... he would drive the same though...
happens after some glue as lock and always on the same machine.....maybe it is an installation problem.
As for the modes of use, I do not know two designers who use the same menus as the keyboard commands that the famous ribbons. everyone personalizes, everyone uses it according to way that it is more productive for them!! ! ! ! ! ! !
personally if I can't do something I try to update the obstacle but it's not for everyone so.
Sure I would like to understand the problem, probably some variables to set up.
happens after some glue as lock and always on the same machine.....maybe it is an installation problem. ......... .
no variable to set.
It rarely happens to me, it is an anomaly that autocad has been taking after for a while.
But if you happen often is another speech, difficult to identify in that case the problem.
"ribbon" but how comfortable adobe, in any application you are immediately productive enough that you can use one in all other vien from if
photoshop
illustrator
indesign
etc.
have a similar interface in all.
but what ribbon is enough that microsoft put that crap on office, the only one who copied it as style was the autodesk
p.s. we talk about interface not of particularity of software
Do you make examples? ?
beh........per esempio. . . ....
  • solidworks
  • creo elements
  • solid edge st
  • space claim
  • ...also buildingsus acca software
this just to quote some of the most famous...if you don't know things, please shut up!
...if you don't know, please shut up!
if anything the opposite if one does not know things must ask.. I asked!! and you did the examples simply.
if one does not know anything and there are no forums to ask, of which it is lawful, answer is only courtesy.
...the only one who copied it as style was the autodesk
in your speech you didn't ask but you said that "the only one who copied it as style (the ui ribbon) was the autodesk". Anyway, you asked and I answered. You learned something new today.
