Merka73
as cabbage I make to create the corner drain on a flat sheet and then add 4 vertical walls to 90° on the 4 sides.
basically I want to make a rectangular box with sheetmatal.
Does anyone have an example on how to do it?
qdo selects the command "corner relief" nn makes me select no geometry.
Can you use it?
Can you use it?
