corner relief in sheetmetal wf5
  • Thread starter Thread starter Merka73
Merka73
as cabbage I make to create the corner drain on a flat sheet and then add 4 vertical walls to 90° on the 4 sides.
basically I want to make a rectangular box with sheetmatal.
Does anyone have an example on how to do it?
qdo selects the command "corner relief" nn makes me select no geometry.
Can you use it?
Meanwhile thank you x the answer.
My problem is that I often use the "falt wall" command x create the walls one by one but in this way I get a nice drain for the sheet.
to make me understand I uploaded 2 different files made with the wf5.
1 file made with the command "flange". I would like to have this result also using the "flat" command but as you see the nn discharge is equal and not even beautiful.
how do I use the "flat" command to control the discharge as well as in the "flange" command? ? ?
no matter which release of the program you are using.
ps: a simple example with 2 walls well made would help me understand how to use qsto command "flat wall". Thank you.
  • New folder.zip
    New folder.zip
ciao,
Why do you make a wall at a time, when you can do them all at once, and without problems, with the flange command?
thanks also to you but I repeat the concept:
I need to make some walls one by one. the files are only simple examples x learn the command but nn center with the reality that I will have to realize.
in these cases, when I am forced to make a fold at a time, I use a make-up: first insert a wall with angle 0 and 1-2 mm long and then the wall at 90° desired. so doing the corner drain goes well.
Damage
I've never heard of that make-up. 1 simple example also x posters nn would spoil if nn is too much trouble.is the length 1 or 2 mm independent of the thickness of the sheet?I used this other trick. I realized a circular or rectangular cut on the desired angle and then I realized the 2 walls that insist on the corner.
I suspect this trick is an index of my ignorance
I don't get it.
I look forward to a clearing example from who knows more about me.
Good morning,
I attach the example where I have made the folds in various ways, of course, when possible, it is preferable to use the flange command, otherwise it takes many features to achieve the same result.
