catapulta00
hello to all I'm going crazy, I can't create a ball like football with 20 hexagons and 12 pots, someone can give me some advice
I think it's the curved faces that interest him. . .but do you care about flat faces or, as in reality, curves?
this discussion already exists linkhello to all I'm going crazy, I can't create a ball like football with 20 hexagons and 12 pots, someone can give me some advice
I did differently from you...hello to all you are too good at this forum. However I was successful and the procedure is similar, perhaps the same as rs4; I first built the truncated ichosaedro and then wrapped by a sphere, I projected the edges of the polyhedron on the surface and fortunately the ball came out.
I have only two problems:
1) the sides of polygons are not all the same, but I think we can solve it with a polyhedron report
2)I don't understand why when I run the whole 20 mm size model fails me; I solved this by saving an iges file and then I worked on that model, but I don't understand why I can't make a 20mm scale projection.
hello and thanks again
I also used the same method.continues the sequence
it would be interesting to see the various ways performed by colleagues exposing their processing steps
this is the bug I usedI also used the same method.
How did you calculate the exact measurement of polygons?
no tipping didn't change it was just to have the sides of the polygons at 20mm per side and I responded to max that he asked me the formula as I had made me the football ball... I calculated sphere and radius,but why if you change the size of the polygons the tipping changes? should not.. .
