modeling exercises
cacciatorino
Can you help me find modeling online exercises? I'll be late this morning, but I can't find them. :confused:
Haven't you learned yet? You've been working on it for months and you're still looking for exercises?
Hand hammer and chisel and go, pedal!
:biggrin:
:biggrin:
No, it's for my father who wants to be impratichied, but I unfortunately live far away...
dirotec, make him a schemetto, clear and concise othersment "lost"!
p.s.: they are "simple" minds, you must have patience!
:biggrin:
After all, I'm still not sleeping at night, thinking about what can happen to my models not totally bound when I turn off the pc at night. :frown: the next morning they will still be as I left them?
and here I want to open a "parents".
two scenarios:
- in the first you have a "paraplegic" where at every "regeneration" the whole path of processing and profiles is repeated to recreate the models that make up your set. attention, models are recreated in the true sense of the word, not only graphically regenerated.
- in the second hypothesis the axieme is loaded by a contextual from a file and regenerated to video.
Where do you think there's more possibility of error?
Have you ever wondered why on all parastrubboli impervert scheleton and topadoun? How come you try to convince everyone that it is better not to bind faces in the assemblies but to connect the schec directly to the models without annihilating the constraints?
ahahahahha...it's true!
even when I went from a parametric sw to I create modeling I made "easy" to get used to the assemblies.
but I sincerely to this thing that move the models I never thought about, but for what reason it is not that spends a solar storm at night moving them.... but because in the parastrubula they move themselves: eek:
There is normally no problem with the models that reside on fixed workstations or on business servers.
The tragedy is when you work with the laptop. the risk that all parts of the axieme fall on the horizontal plane during the insertion/transport in the bag is very high.
for now the only solution (other than buying the parametric module specially created to overcome these problems) is to transport the laptop always horizontally, with a lot of caution and without waste.
to the ptc-cocreate recommend a shopping cart modified or even better a wheelchair, possibly in oak wood, pushed by a Romanian farmer :rolleyes: :biggrin:
the problem actually arises, often when working in group.
If a man works at a "seek-member" and moves things to the house, he settles his own together, but he disposes of all the assemblies of others.
It's typical with bookshelf sets or, anyway, shared, if to reposition them move the components instead of "entry" the group, they come out the most fun things.
then there is the problem that you have to be very careful when selecting small shifts, there is who "diverts" to move objects "hand" instead of using smart snaps and you find spaces, micrometric overlaps etc.
the assembly module and the parametric module are a "holy hand", but they cost three eyes of the head and to the ptc commercials you would have to pick up the eyes!
:smile:
You shut up, steamed mats!:biggrin:
you find yourself spaces, micrometric overlapping etc..
the incredible!!! He admitted it!!!! were years that denied the evidence!!!!! :biggrin:
However, if the cad allows "risk" mode of work, excuse me but this is a perfect example of "bad design"....:cool:
on commercial hp-cocreate-ptc I think like you, but if they sell, obviously they are right.. .
two scenarios:
I was joking, but you don't know what brainwashing did to me in the company when I was switched to modeling, just about the mistakes not to be made to live quietly, like "serious window" or "copy a level" etc. etc.
In the end, it's a cad you don't have to trust so much, which you can think about designing and background work without breaking your boxes. . .
And then I don't know, it will be that if and swx are very robust, but the errors in the charging phase of the axieme are very rare.
in relation to the regeneration of the parts, attention: it is performed only in phase of modification of the part. when the part is loaded from the server, the system reads the raw and naked geometry stored in the part file, while the "history" that led to that result is loaded only when needed: basically in the part file the geometry is described twice: as "block file" (the ficiurs tree) and as pure geometry (the solid base).
this with ferrivecchi, I use 99% faces and plans and the "parastrubble" does not make a fold, neither in topa-daun nor in topa-ap.
In five and a half years, never seen a failed couple... unless I'm the one who's caxxate.
there are parastrubboli and parastrubboli... :smile:
