eboss
You can use other profile sketch points, in the structural element's propitiance you can set a different alignment, using another point that is not the origin of the profile sketch.
Besides you can set the type the type of treatment edge, you will see that if you remove the flag from merge shortened bodies to angle you can get what you want.
the profile you need to save it in the default folder by going to also create the under folders for example:
c:\program files\solidworks corp\solidworks\lang\italian\weldment profiles\iso\angle iron
if you place them when you go to use the structural element command you can also select your profile.
if you create the solid and insert it into the toolboxes you can't put it in one part, but you have to work in the environment together. Are you working together?
