eboss
the profile follows the sketch then, with edge treatment you can manage what type of union you want between the profiles example if you want them at 45° angle or insert a closure...(I don't know if I understand what you mean )I tried that command, too. but what I ask is if the measure (for example) of the 2 short vertical profiles is determinable externally to the guide sketch or if I already have to calculate the 2 measures to get to the center of the 2 profiles above and below?
