19marco77
Good morning people,
to simplify work in the workshop I should solve this:
in welding environment during the modeling of the structures I also add the sheet panelling. using structural profiles the sheet enters the groove and must therefore be larger than the "hole" (in the design I make it match the size of the hole).
I should give an automatic name to the description item in the cutting table but I have no idea how to place a quota within the description.
type:
aluminium sheet ("height rate" +15mm) x ("width rate" +15mm) x 2
so that in the description of the cutting table I appear:
aluminium sheet 500x400x2
In this way if I change quotas to the structure also updates the description of the various panels. Is it possible?
type:
