ribbon bar disappear at the opening of a dwg
  • Thread starter Thread starter 19junior86
19junior86
Hello, I have the following problem:
on a computer windows xp, service pack 3, use autocad 2010 along with a carpentry application (I don't know if I can say the name) that integrates with the autocad commands.
autocad has already installed the most recent service packs.
I recently passed to the ribbon bars that I find very useful, and this carpentry application adds to me three more ribbon bars as well as those that are present in autocad of defalut. These ribbon bars appear only if you open a dwg from the integrated environment of the carpentry program, otherwise, if I open autocad normally, or I open a design with autocad without going through the integrated environment, I fill the ribbons only of autocad.
this to make you understand the overview of the situation. . .
in practice this happens when I open the first drawing everything ok.
but when I go to open drawings from the second on, both from the integrated environment and from autocad, the three ribbons of the carpentry application disappear. to make them recompile I have to click again on the bottom right bar that displays the various working areas, and reload my work area that I saved when all ribbons were normally present. are two clicks, but doing it for every drawing I open becomes frustrating, especially when you have so many dwg to manage.
I have already contacted the provider of the program, tried to beat him with my computer using teamwiewer via remote connection, but he didn't fix anything!
So I thought I'd ask...
I'm not very experienced in working areas, toolbars and other things (I'm always afraid to mess up) so maybe if you ask me to check out some options I will do it and I will tell you....
edit: after taking a look around I saw that there are no (rightly...) problems to say the name of the programs! the application is the technometal
Thank you, but it seems to me that that works for a single design, I would like it to work on all the drawings!
for example says "when using a parameter, you need to add a space after it, then the name of a file, a path or a view between quotes"
but if I want it to work on all drawings, can it work if I insert the following path?"c:\programmi\autocad 2010\acad.exe /w "tecnometal"where technometal is my default work area?
Thank you, but I seem to understand that that works for single design, I would like it to work on all the drawings!...
Why do you open a dwg change work area?
....can work if I insert the following path?"c:\programmi\autocad 2010\acad.exe /w "tecnometal"where technometal is my default work area?
you lack quotes: "c:\programmi\autocad 2010\acad.exe" tecnometal
I don't change my work area, when I open a drawing the right work area is loaded, but I have to click on it again to reload the technometal ribbons.
I will try to insert the string then
niente, non va.
if it can be useful, take off what is written automatically in the text window at the start of the first drawing, when you charge me everything:
the customization file has been loaded without problems. group of
customization: acad
customization: custom
customization: impression
customization: ♪
opening a file in the 2010 autocad format.
replacement of [simplex.shx] con [txt].
rigenerazione modello in corso.
connecting to com object sg3profsection
connecting to com object sg3robotsection
caricamento delle dll del modeler in corso.
caricamento delle utilità dei menu di autocad avvenuto.
loading tecnometal...........
gruppo di personalizzazione sconosciuto: steelg
file di personalizzazione scaricato senza problemi. gruppo di
personalizzazione: sgr
il file di personalizzazione è stato caricato senza problemi. gruppo di
entering immediate startup
loading
c:\windows\steel&graphics_shared\application\objectenabler\tec3dprofileobj_18.db
x...already loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\artobjects_18.dbx...a
lready loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\tecdrawtableobj_18.db
x...already loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\artmanageentity_18.db
x...already loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\tec3dloads_18.dbx...a
lready loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\artenground_18.dbx...
already loaded
loading
c:\windows\steel&graphics_shared\application\objectenabler\tecconv3d2dobj_18.dbx
...already loaded
loading c:\steel\tecnometal\prg\tecgenconfig_18.arx...ok.
loading c:\steel\tecnometal\prg\tec4d2acis_18.arx...ok.
loading c:\steel\tecnometal\prg\tecbaseplate3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tecbracing3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tecbrowsedb_18.arx...
init browsing services....
init com object...
ok...ok.
loading c:\steel\tecnometal\prg\tecconnection3d_18.arx...ok.
loading c:\steel\tecnometal\prg\teccreatecam_18.arx...ok.
loading c:\steel\tecnometal\prg\tec3dprofileui_18.arx...
loaded 300 profiles
loaded 0 bolts
ok.
loading c:\steel\tecnometal\prg\techandrail3d_18.arx...ok.
loading c:\steel\tecnometal\prg\teclispservice_18.arx...ok.
loading c:\steel\tecnometal\prg\teclist_18.arx...ok.
loading c:\steel\tecnometal\prg\tecsplice3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tecstep3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tecwireframe3d_18.arx...ok.
loading c:\steel\tecnometal\prg\teccatalog_18.arx...ok.
loading c:\steel\tecnometal\prg\tecdbase_18.arx...ok.
loading c:\steel\tecnometal\prg\tecdictionary_18.arx...ok.
loading c:\steel\tecnometal\prg\artsectionui_18.arx...ok.
loading c:\steel\tecnometal\prg\tecdrawtableui_18.arx...ok.
loading c:\steel\tecnometal\prg\tecmecexploded_18.arx...ok.
loading c:\steel\tecnometal\prg\tecmanageentity3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tec3dprofileui2_18.arx...ok.
loading c:\steel\tecnometal\prg\teclist3d_18.arx...ok.
loading c:\steel\tecnometal\prg\tecusershape3d_18.arx...ok.
loading c:\steel\tecnometal\prg\artmasselementui_18.arx...ok.
loading c:\steel\tecnometal\prg\teccalcstruct_18.arx...ok.
loading c:\steel\tecnometal\prg\tecconv3d2dui_18.arx...ok.
loading c:\steel\tecnometal\prg\tecmbcreateexcel_18.arx...ok.
loading c:\steel\tecnometal\prg\tecimportexportrevit_18.arx...ok.
builded teccfg_doc_path
builded teccfg_stp_path
builded teccfg_stp_color
builded teccfg_stp_draw
builded teccfg_stp_bolt
builded teccfg_stp_list
builded teccfg_stp_mark
builded teccfg_grp_prp
builded teccfg_cmm_prp
builded teccfg_dwg_prp
...ok*annullato*
digitare un'opzione [?/Def/coRrente/Nuovo/RInomina/ON/OFF/Colore/Tipolinea/SPesslin/MAteriali/Stampa
/conGela/SCongela/BLocca/SBlocca/stAto/DEScrizione/RIConcilia]:
dwg file autodesk. this is a certified dwg file whose last rescue is
with a self-desk application or a licensed application
autodesk.
command: _ribbon
command: lineacom
below when I open the following drawings:
regeneration model in progress.
Loading the autocad menu utilities occurred.
loading technometal.......
unknown customization group: steel
download customization files without problems. group of
customization: ♪
customization: ♪
type an option [?/Def/coRrente/Nuovo/RInomina/ON/OFF/Colore/Tipolinea/SPesslin/MAteriali/Stampa
autodesk.
I don't know if that's the problem.
and below when I go to reload the work area to display the ribbons again
type new value for wscurrent <"tecnometal">: engineering
customization: acad
customization: ♪
command:
command:
WORLD
type new value for wscurrent <"tecnometal">: *nothing*
I thought, can't you make sure that every time I start a drawing automatically starts the macro "wscurrent - tecnometal"? ?
