PierArg
- load losses are "resistances", it is not that they return the fluid back. see them as obstacles.Yes, but it is irresponsible because you have to win only a few grams of precarious.
Have you ever seen a vn?
I've never seen her, I'll get a study, and then I'll let you know.
yes this, xò in theory the tube placed at the venturi exit having a diameter of 4mm, and being of rubber will cause friction that results in a loss of load, and makes the steam come back and prefer to pass for the reservoir (at least in part)....
When you return to the vn, you say that by putting it after the divergent system could work?(i.e., the steam does not return to the cleaner)
However, I have to put the rubber tube after the venturi tube... I will never come out of it![]()
- Why 4mm in diameter? the flow of steam that must pass what is it?
After your venturi, you can put all the pipe you want. there are other applications where after the venturi there are at least 5-6 meters of pipe (see washing machines).
Can you measure the pressure in the tube tract before the venturi?
