modeling piece
Thank you so much to all!
ps: I tried first to do by myself and then I looked at the file posted so as to see and fill the gaps I met.
Thank you again!
Thank you again!
of nothing,
but do not get used to too frequent aids.
marcof was right that I gave you the model too soon.
but at least now you have had a reference parameter.
Could you upload the model you created, so we can take a look?
I doubt it's a whole tube.
How would you realize in a tube the 112 long asola and that other upper rectangular quarry?
Whereas it is a mesozoic design :smile: , I don't think they had dip electroerosion to do that.
To me it seems like a chirone-torncasa exercise. . .
Sure.
The problem is that having seen yours now I have too cool in memory, so I'll do it again in the morning.
See you soon!
ps: I did it more or less like you!
ps: to do everything I used a little orchard and a half.
I don't know why but he often gave me ultra-definite sketch. I had to cancel and squirt again at least 3 times!
See you soon!
not bad... but it is 90 wide while on the drawing is 87 wide.
they would miss a couple of fittings on the two outer areas where there are ø12 holes.
the modeling procedure (at least for my working method is correct).
1) material addition functions
2) material removal functions (if you can't define the piece by adding material).
3) holes
4) fittings/smuses.
I normally work like this (in order to hold fittings and bevels at the end of the piece to suspend them in simplified configurations).
I hope I helped you.
I steal a nice 27! :-)
ps: the proposed drawings (some) were more copmples than those that came out to me.
less bad I would say!
